Post your Computer
RE: Post your Computer
Postby shovenose » April 13th, 2011, 7:06 am
thats a good computer you have there!
Only problem is, raidmax makes bad psus...you should get a better one; seasonic, antec, corsair, enermax, etc, all make good units.
Postby c_hegge » April 13th, 2011, 1:57 pm
The higher end raidmaxes are made by ATNG and are
not all that bad like their low end sun pro built units.
Postby Klinc » April 21st, 2011, 2:44 am
I got banned from Tomshardware for allegedly stealing a guy called Klincs from Hardware Secrets computer specs.
Here is my rig
I7-2600k @4.8Ghz | ASUS MAXIMUS IV EXTREME | 4x 2gb Corsair Vengeance 1867mhz CL8 10-9-24 1T 1.600V| 3x EVGA Gtx580s| OCZ Vertex 2 SF 180gb | CORSAIR AX1200
(There used to be images here, but Photofuckit removed them. :frustrated:)
My 2nd rig is still under construction where I will post the pics when I'm done coz I'm busy modding the case. I moved my 3x Zotacs 580s over to that setup.
Reason: Lost images
3DMARK11
Klinc
Postby c_hegge » April 21st, 2011, 2:16 pm
WOW! Impressive PC (other than my hatred of ASUS motherboards). Must have cost you a fortune
Postby shovenose » April 21st, 2011, 4:18 pm
I never quite understood why you take issue with Asus. They are my preferred motherboard manufacurer!
Postby c_hegge » April 21st, 2011, 4:59 pm
Because I have seen too many drop dead after a couple of years in service. No bad caps, no PSU failures, no obviouse cause, but they just die. Gigabyte, however just keep working. Plus, asus are a pain to re-cap, since you have to install the caps backwards to the usual + and - markings.
My preferred manufacturers (1 being first preferrence) are:
1. DFI Lanparty series
2. Gigabyte
3. Intel (obviously not for an AMD system)
4. MSI
5. Asus
Postby shovenose » April 21st, 2011, 6:40 pm
good point. but the only Asus board that just died on me was a socket a/462 amd athlon xp i sold to my moms boss lol and it died :( so i gave her a different pc lol)
Postby c_hegge » April 21st, 2011, 7:11 pm
We've been seeing a LOT of ASUS boards die much younger than that (like Skt. AM2 and 775).
btw, after the recent upgrade, my system specs now look more like this:
Core 2 E8400 3GHz overclocked to 3.6GHz, Gigabyte GA-EP45-DS3L Motherboard, 4GB Kingston DDR2, 320GB WD Hard disk, 1760MB nVidia GTX295, Sony DVD Bruner, In Win Power Man IP-P600CQ3-2 600W PSU, Antec Twelve Hundred Case, Hauppauge TV Tuner, Windows XP Pro
Postby shovenose » April 21st, 2011, 7:57 pm
My PC sucks :( i dont like it anymore the piece of crap.
Postby c_hegge » April 21st, 2011, 9:28 pm
which one?
