Post your Computer
Re: Post your Computer
Postby c_hegge » February 27th, 2012, 4:50 pm
They are quiet when they are on low (they have manual speed controls). They've probably spent 90% of their life on low. They would probably have failed much sooner if they'd been on high most of the time.
Postby duckula » February 5th, 2013, 5:53 pm
Gear upgraded: intel i5 2550K 3.4G + Gigabyte H61M-USB3-B3 (can't overclock :s ) + Kingston DDR3 1333 4G + Samsung 830 series 128G SSD + WD6400AAKS +Liteon 24X DVD-RW + XFX HD4650 :dodgy:
Postby c_hegge » February 7th, 2013, 2:17 am
That should be decent performance. H61 boards don't often OC well, so I wouldn't bother with a K CPU edition on that board (unless you plan to upgrade in the future).
Postby duckula » February 7th, 2013, 11:30 pm
i5 2550k is almost the cheapest LGA1155 i5 processor I can get on the market. It cost me about $138. :D
Postby c_hegge » February 9th, 2013, 1:35 am
Nice. It's a good option then.
Postby steenss » February 11th, 2013, 6:21 am
Those Sandy Bridge CPUs are a great deal. I've been considering one myself. Still got a Bloomfield i7 920, but both my home server motherboards have died so I need to get something. Had hoped to wait 'til Haswell.
Anyone want a Brisbane 4400+? Nvidia chipset won't take another reflow. :@
steenss
Postby c_hegge » February 11th, 2013, 1:04 pm
I recently had an identical board come my way, although the chipset was still fine. It just had bad caps (Chemi-con KZG), but I stuck a fan on the chipset heatsink while I was at it, which should make it last longer. If you don't want the CPU, I'll be happy to take it off your hands. You could slip it in with the PSUs. I won't pay for it, though, since I do have a spare one already. They're still good for upgrading cheap compaqs that come with Semprons and Windows Vista.
Postby steenss » March 2nd, 2013, 9:57 pm
Heh, no worries mate. I tend to give my old gear away. That's bitten me this time, as I could've used my old Q6600 CPUs to update the home servers. Anyone got a C2Q CPU (or two) preferably Yorkfield (Q8/9xxx) lying around? I'd like to underclock/undervolt for silent running. No probs with recompensing.
steenss
Users browsing this forum: No registered users and 25 guests
