Cable bundling methods
Which method(s) do you like for keeping cables/wires in neat bundles?
"Zip" ties
1
25%
Twist-ties (ONLY where safe against short-circuiting)
1
25%
Velcro straps
Ribbon cables
Sleeving (overall, not individual!)
Twisting (2 strands)
1
25%
Twisting (3+ strands)
Braiding (3+ strands)
1
25%
Other
Total votes : 4
Postby LongRunner » May 14th, 2017, 7:18 pm
I'm unsure if I'd be considered "weird" for it, but I'm not a big fan of over-sleeved wire bundles on PSUs (for example, though by no means limited to them); when I built my current PC, I found that the sleeves on the Seasonic G-360's output leads added considerable stiffness - to the point that I just decided "to hell with the warranty" and cut them all off, adding plenty of "zip" ties to make up for it.
But at least I can see the purpose of overall sleeves - they do hold the wires together neatly enough. I'd hate to work with individually sleeved wires, on the other hand - all that those really do is add needless cost and bulk.
This brings me to cable bundling, and the various ways it can be done. Apart from sleeving, here's my own quick evaluation of (some of) the methods:
  • "Zip" ties: Cheaply available and easy to apply, but difficult to remove and the protruding bit can get physically caught.
  • Twist ties: Also cheaply available, and easy to apply and remove, but the steel wire inside them can present a short-circuit danger if its ends touch circuitry. I mainly use them to keep cables from getting tangled while stored.
  • Ribbon cables: Cost-effective to manufacture and can save space with smaller numbers of wires, but not so much with bigger ones (as anyone who remembers parallel ATA/IDE or SCSI knows). (Although, I don't use the "rounded" PATA cables either, on the grounds that they may not meet the required electrical characteristics…)
  • Twisting the wires together: Can work OK, but only as long as the bundle doesn't then un-twist. You may (or may not) gain some flexibility in doing it. I've split the poll option in two as braiding is preferable for 3 or more strands, but twisting may still be useful for 2.
  • Braiding: Probably the best way of securely keeping 3 or more strands together without additional materials, and maintains reasonable flexibility if done well. The complication is in knowing (and applying) the correct procedure, which depends on the number of wires (and particularly whether that number is odd or even). (Although, don't forget that the sleeves most commonly applied to PSU output cables are themselves braids…)
I've attached a picture of a braiding job I made just today, as an example of how it would look (and also to validate the procedure I used). If you like, I could even write a "how-to" article for the main site… :cool:
The twin "Berg" adapter lead that came with my G-360 (but which I haven't used to date). The sleeved half is as originally manufactured, the other half has been braided by me (after cutting the original sleeve off, obviously). The braid is significantly more flexible than the sleeved part.
Sleeving vs. Braiding test.jpg (46.57 KiB) Viewed 22152 times
Re: Cable bundling methods
Postby Brennes » September 27th, 2019, 4:36 am
It's zip ties for me too. They're just cheap and convenient. I can see there are a lot better methods though. More power to the people who invest more time into their cable management. haha
Brennes
Postby Behemot » November 3rd, 2019, 9:09 am
It depends, on the PSU/case and what material I have available. But usually, I use some combination of properly leading/hiding the cabling and than using twist ties (it's usually so far from any contacts that I don't really care about conductivity of either the steel wire, or copper wire - as I often use short cut-offs of structured cabling, which is quite good for ties :D). If available, than velcro ties.
Don't get individually sleeved cables as well. Could look nice, but everything else are just disadvantages.
Users browsing this forum: No registered users and 5 guests
