See if you can find what's wrong with this. Actually, on second thoughts, maybe it would be easier to find what's right with it.
The PC is a mITX with a Core 2 Quad CPU, no case fans, an nVidia chipset, a cheap sleve-bearing graphics card fan (which was ceased up), and TK and G-Luxon capacitors all over the motherboard (and yes, the TKs were vented when I got my hands on it).
The picture was taken after I downgraded the CPU to a core 2 duo, added a chipset fan (a sunon maglev ball-bearing), removed the graphics card, and replaced the TK caps with Nichicon HM and the G-Luxons with Rubycon ZL. I had to mod the PSU a bit to get power to the fan. The only spare connector was the extra 4 pins on the 24 pin ATX connector (the mobo only has a 20-pin connector). I cut the connector off and soldered a 3-pin fan connector in it's place (using the 5v rail to power the fan, since it spins at like 4 or 5000 RPM at 12v and makes too much noise).
No prizes for guessing what brand it is
