AC97 or HD Audio?
AC97 or HD Audio?
Postby shovenose » October 29th, 2011, 7:43 am
My Cooler Master case has two options to plug into my motherboard audio connector. My mobo is a DFI 865PE-TAG. Which connector do I use? or does it matter?
Re: AC97 or HD Audio?
Postby c_hegge » October 29th, 2011, 12:53 pm
http://www.newegg.com/Product/Product.a ... 6813136156
Not that hard to find out. just scroll down to the audio section.
Onboard Audio
Audio chipset: AC97 codec
Postby shovenose » October 29th, 2011, 6:44 pm
I didn't think to look there. Thanks Mr. Detective. ;)
