Can't get my computer to work...again.
Postby Nuke » April 14th, 2012, 9:27 am
Yeah, yet again, it won't turn on. No clue what it is. Have NOT tried the paperclip, since I doubt that it's my second motherboard that broke.
Nuke
Re: Can't get my computer to work...again.
Postby shovenose » April 14th, 2012, 3:22 pm
Did you remember the 4 or 8-pin CPU power connector. That's easily forgotten.
Does it not turn on at all? Or do the fans spin, etc. but nothing shows up on the screen?
Postby Nuke » April 14th, 2012, 5:36 pm
Fans not spinning. Not turning on at all.
Nuke
Postby shovenose » April 14th, 2012, 9:10 pm
Stupid I know but: are you sure your power cord is firmly plugged in, to a functional outlet, and firmly plugged into the psu, and the switch on the psu is on?
Postby c_hegge » April 15th, 2012, 12:44 am
Try it with another PSU. If it doesn't power on with two motherboards, then that's probably the next most likely suspect.
Postby Nuke » April 15th, 2012, 7:16 am
This is the same PSU that I used on that Asus motherboard awhile back, so I know it works.
Everything that Shovenose asked about seems to check out.
Nuke
Postby shovenose » April 15th, 2012, 8:18 am
Are you sure you've wired up the power button correctly?
Postby Nuke » April 15th, 2012, 1:51 pm
I'll go check by reversing the position of it to go where I currently have reset. But currently, I do indeed believe it to be wired correctly.
Nuke
Postby c_hegge » April 15th, 2012, 2:21 pm
Nuke wrote:This is the same PSU that I used on that Asus motherboard awhile back, so I know it works.
Didn't that motherboard have the same problem?
Postby Nuke » April 15th, 2012, 4:53 pm
Yeah.
Nuke
