ASUS Q501L
ASUS Q501L
Postby shovenose » November 23rd, 2013, 9:26 pm
http://www.bestbuy.com/site/15-6-touch- ... Id=8937121
Really loving the 1920x1080P screen so far. Makes me realize just how much people with 1366x768 screens are missing. Anyway, the CPU and GPU are nothing to get all excited about but for web design/development, server management, and trolling forums it's plenty.
Re: ASUS Q501L
Postby c_hegge » November 23rd, 2013, 9:55 pm
Windows Hate. Enough said.
The other issue I can see with that is that full HD is too high for a 15.6" screen. If I go much higher than 1366x768 on a screen that size, I can't read it well (unless I increase the size of everything, which kind of defeats the purpose). Full HD is only for 22" or bigger IMO.
Re: ASUS Q501L
Postby shovenose » November 28th, 2013, 7:30 pm
How I disagree with you!
The text is perfectly readable.
The only time 1366x768 should be used is on crappy 10" netbooks or tablets.
