True Fusion: AMD A8-3800 APU Review @xbitlabs
Discuss CPUs (Processors) here.
Postby duckula » June 30th, 2011, 6:13 am
In the end choosing Llano for any type of entry-level system will depend solely on your needs and goals. If gaming performance is your number 1 priority, but you are not ready to invest into a mainstream or high-end graphics card, then there is hardly anything better than an AMD A8 series processor. Especially, since there are at least two ways of boosting the graphics performance at minimal cost. The first one is overclocking, and the second one is Dual Graphics technology that allows combining APU graphics with an inexpensive discrete graphics card within an asymmetric CrossFire configuration.
If you are looking to build an inexpensive platform with high computational potential, then Llano won’t be the way to go. And in this case it doesn’t make sense to pay extra for the high-quality graphics core built into this APU. Although Fusion concept implies that stream processors from the APU graphics core can be used for calculations and acceleration of popular general-purpose applications, it doesn’t yet work well enough.
http://www.xbitlabs.com/articles/cpu/di ... -3800.html
RE: True Fusion: AMD A8-3800 APU Review @xbitlabs
Postby shovenose » June 30th, 2011, 7:30 am
Huh. And here I go thinking AMD is cheap and caters to the low end.
They need to focus on creating a processor faster and cheaper than Intel.
Then they can do all this other crap!
lol
Postby duckula » July 3rd, 2011, 7:09 pm
A8-3850 and A6-3650 are available on newegg now. They're $139.99 and $119.99 respectively.
http://www.newegg.com/Product/Product.a ... =a8%203850
http://www.newegg.com/Product/Product.a ... =A6%203650
Return to CPU
