What's the longest-running HDD you have???
Re: What's the longest-running HDD you have???
Postby LongRunner » June 13th, 2013, 9:40 pm
A DTLA-307020. With no bad sectors.
Postby LongRunner » August 6th, 2013, 3:17 am
LongRunner wrote:...ST3120026A...no CRC errors...
Now there are six of them, but that's because I connected it with a 40-wire cable to deliberately limit the interface speed to test its efficiency (in terms of raw bandwidth compared to actual data transferred), and although the hosts are designed to restrict the speed when running with a 40-wire cable, they apparently don't limit it enough. Still flawless otherwise.
Also, I figured out how Samsungs report their runtime and updated the original post.
Postby LongRunner » October 8th, 2013, 8:45 am
For once in a lifetime...
Okay, it's a bit of an arbitrary thing to mention, but I bet you've never seen it before.
Rolling counter zeroed out.PNG (36.9 KiB) Viewed 21154 times
Postby LongRunner » August 8th, 2014, 8:02 pm
Update: As I have seldom used my ST3120026A, one of the WD800JD-00LSA0s in my older system has overtaken it in runtime, with 37,230 hours as of now (though only 728 start/stops). The other has 32,128 hours and 1,375 start/stops. S.M.A.R.T. records on both are clean save for one UDMA CRC error each.
