Defragmenting an SSD
Postby shovenose » April 5th, 2011, 11:53 am
I have a 32GB SSD in my laptop. My file fragmentations is at 43%, which is pretty bad, (at least I think it is).
I want to defrag it but I've heard lots of things, ranging from "It won't do anythigng" to "it will make your SSD blow up"...
Any advice?
RE: Defragmenting an SSD
Postby c_hegge » April 5th, 2011, 1:49 pm
NEVER under any circumstances defrag an SSD. It wears them out quicker amd they actually work better with the files fragmented since, unlike a
mechanical HDD, they can read in several places at a time. In windows 7, if it detects that you have an SSD, it actually disables defragging.
Postby shovenose » April 5th, 2011, 4:50 pm
oh. ok :-)
Postby Klinc » April 21st, 2011, 2:03 am
Why is it fragmented? do not touch a ssd with a defragmentation program. Is trim enabled?
3DMARK11
Klinc
Postby shovenose » April 21st, 2011, 11:31 am
It is windows xp on. a transcend 32gb ide ssd...trim isnt supported!
Postby c_hegge » April 21st, 2011, 2:20 pm
You can get IDE SSDs?
Postby shovenose » April 21st, 2011, 4:04 pm
$115 newegg.com
Postby c_hegge » April 21st, 2011, 5:03 pm
Oh, right. If only I still had my Toshiba Portege M300. I had an aftermarket battery which stuck out the back a bit for it. It lasted about 10 hours on a mechanical HDD. It would have been nice to see what it would have done with an SSD (12 hours maybe?).
Postby RWenger » April 21st, 2011, 9:57 pm
I have one of that laptop's successors: a Toshiba Porgege M780. I'll post specs in the "Post Your Computer" thread.
RWenger
Postby c_hegge » April 21st, 2011, 10:05 pm
yeah. porteges are great little machines
