This thread is so you can post your HDD opinions and experiences. Set it in this basic format:
HDD model (and firmware version if desired) (key specifications – MB or GB/surface and # of heads (if not documented and not clear from examining the drive, enter “unknown configuration”; for Maxtors with model numbers ending in 0, check the second character in the serial number), spindle speed, bearing type (BB – ball bearing or FDB – fluid-dynamic bearing), contact start/stop (CSS) or load/unload (L/U), interface (including command queueing if supported), cache size, form factor if it isn't 3.5″*/1″ high, other relevant details)
Comments (transfer rate, access time, noise, etc.)
*The form factor is really misnamed. The width of the drive casing is 4″ and the disks in most 7200RPM and slower drives are 95mm. It was derived from the 3.5″ floppy disk drive which had the same external dimensions (though most 3.5″ HDDs have different mounting holes)…which was itself misnamed, as the floppy disk in question was actually 90mm. 5.25″ HDDs had 130mm disks, and the floppy disk bearing the name was 133 and a third. The drives had an outer width of 5.75″. The pre-PC 8″ floppy disks were actually 200mm. “Full-height” 5.25″ drives were 3.25″ height and “half-height” are 1.625″ high (and while long dead for floppies and HDDs, 5.25″ HH lives on for optical drives). Quantum Bigfoots were 0.75″ or 1″ high. 3.5″ drives are usually 5.75″ deep (the exception being Seagate's mid-1990s Decathlon family, later renamed Medalist SL, which in addition to being 0.75″ high was 5″ deep) and 5.25″ drives were originally 8″ deep, but modern optical drives are much shorter.
“Ultra ATA” was a mixed-up marketing term - there are PIO, DMA, and Ultra DMA transfer modes, which have the following bandwidth (ignoring overhead):
PIO mode 0: 3.33MB/s
PIO mode 1: 5.22MB/s
PIO mode 2: 8.33MB/s
PIO mode 3: 11.1MB/s
PIO mode 4: 16.7MB/s
Multi-word DMA mode 0: 4.17MB/s
Multi-word DMA mode 1: 13.3MB/s
Multi-word DMA mode 2: 16.7MB/s
Ultra DMA mode 0: 16.7MB/s
Ultra DMA mode 1: 25.0MB/s
Ultra DMA mode 2: 33.3MB/s (“Ultra ATA/33”)
Ultra DMA mode 3: 44.4MB/s
Ultra DMA mode 4: 66.7MB/s (“Ultra ATA/66”)
Ultra DMA mode 5: 100MB/s (“Ultra ATA/100”)
Ultra DMA mode 6: 133MB/s (“Ultra ATA/133”)
(There was also single-word DMA, but no-one really used that.)
Now for some of mine:
WD800JD-00LSA0 (40GB/surface, 2 heads, 7200RPM, FDB, CSS, SATA 300MB/s, 8MiB cache)
One of the “black top” generation. Access time is slow (≈19ms) with AAM on. With AAM off it's ≈15ms. Nothing too special there but small variations in access time can easily be overshadowed by differences in caching (StorageReview's tests show a big difference in application performance between otherwise-equivalent 2MiB and 8MiB drives, and many high-speed server drives are ill-suited to desktop use). Seek noise is just audible in use (with AAM off). I had 2 of these in my previous main PC – one for system and one for user data; I occasionally connect a few others.
(Technically, it ought to be called a “WD800JS” – not that it makes any real difference, of course…)
ST31000528AS (firmware CC38) (250GB/surface, 4 heads, 7200RPM, FDB, CSS, SATA 300MB/s NCQ, 32MiB cache)
The third drive in my previous main PC, which was used primarily for multimedia files. It wasn't heavily used by any means (it spun as long as my PC was on, but was seldom accessed); it held up okay for a while, but eventually reallocated quite a few sectors and also developed at least one uncorrectable error. It's a disappointment in general – spindle vibration is low, but seeking substantially vibrates the computer case and seek noise has an obtrusive tonality. Oddly enough, this drive reported itself as being AAM capable, but changing the setting did nothing. I can't recommend this firmware version – some of you might be lucky enough to have one with a different, quieter firmware, but buying one of these drives without knowing the firmware version is a gamble.
ST3120026A (firmware 3.06) (40GB/surface, 3 heads, 7200RPM, FDB, CSS, UDMA 5, 8MiB cache, Agere 4490D6+SH6950)
Still going strong after 34,398 hours of runtime. This was meant to be in an extra PC of mine, but I couldn't use that PC at the time (ran into a design flaw with Windows Product Activation) so I then removed it and copied some files across; I'm not sure what will become of the PC in question.
Seeking is audible but neither sharp nor tonal; interestingly, it seemed louder when cold.
After years of storage in my very humid shed the heads have suffered, but surprisingly with only slightly-reduced net STR and still no bad sectors!
Quantum Fireball LCT20 10 (10.25GB/surface, 1 head, 4400RPM, BB, CSS, UDMA 5, 512KiB cache)
This drive runs without errors but the spindle bearings are quite loud (so much for “reducing noise” by slowing the spindle). The seeks are very quiet (even with AAM off), but very slow (19ms access), which is made worse by the small cache. I've been on a system with the 20GB version and it was unbearable.
WD360GD-00FLA1 (18.5GB/surface, 2 heads, 10kRPM, FDB, CSS, SATA 150MB/s TCQ (bridged), 8MiB cache)
One of the heaviest drives I have (748g), tied with the WD3003FZEX-00Z4SA0. Idling is quiet enough but the seeking sounds like thunder. (I guess I shouldn't be too surprised – speed was the number one priority with these drives.) A pity, as I was thinking of running a system from that drive to check out the performance increase. NOTE: Do not confuse this drive with the WD360GD-00FNA0, which was the first-generation Raptor with ball bearings.
Maxtor 4R080L0 QuickView (40GB/surface, 2 heads, 5400RPM, FDB, CSS, UDMA 6, 2MiB cache)
Came from a video recorder. Has 106 reallocated sectors. With AAM off the seeking is loud and sharp, but the access time is still 17.5ms. With AAM on it jumps to 22ms. Basically, the DiamondMax 16 line is the spiritual successor to the Seagate U6. (See also the results for the 4R160L0 in StorageReview's database. Compare with Samsung SV1604N and the 7200RPM + 2MiB drive of your choice.)
