by c_hegge » July 5th, 2011, 1:42 am
OK, so I finally got some replacment caps (mostly panny and rubycon, with 1 samxon GD series/Good series). You can see it on the test bench (Yes, that is my re-built 400W Rexpower PSU to the right) and in the hardware monitor section of the BIOS.
Several of the original GSC caps had bulging rubber seals. The 3rd one in from the left on the bottom row had electrolyte all over the seal.
No wonder it doesn't work! You installed the coils backwards!
