motherboard wont stat psu
Postby bharath » July 20th, 2011, 9:51 am
I had one old motherboard which which might be pentium 3 and i dont have processors as i got this from a friend.this motherboard wont starts i didnot inserted any cpu but does this starts without cpu
I connected only psu to motherboard and tried to switch on but the psu wont starts.As for searching in google the answer is capacitors are bulged but their are none.any help may be the capacitors are dead and i want to remove the faulty one.
bharath
RE: motherboard wont stat psu
Postby shovenose » July 20th, 2011, 11:21 am
You have to have compatible CPU and RAM in there to even test. It won't do anything without a CPU
Postby bharath » July 20th, 2011, 8:29 pm
This is the motherboard http://www.biostar.com.tw/app/en/mb/con ... p?S_ID=155
I had Ram earlier in my old cpu but was given to other person however i think i need cpu too to test but if i bought from store and the mb wont work then my money will waste
Supports FSB 66/100/133MHz
how to find out this type of cpu in systems.Few of them had old systems so i may try to find in them.i mean compatible cpu
bharath
Postby shovenose » July 20th, 2011, 9:21 pm
http://ebay.com/ I'm sure you can find one for cheap!
Postby bharath » July 20th, 2011, 10:40 pm
I have asked cpu specifications and i know ebay but never bought from their and i am unable to buy online since i dont have CC.
bharath
Postby shovenose » July 20th, 2011, 11:40 pm
Oh. Um.
Local PC shop should have one lying around for a few bucks. Like $10 or less I would think!
Postby bharath » July 21st, 2011, 7:47 am
Their are some shops or have to recover from old pcs but looking to borrow from friend.
ps i am asking again what type of cpu should i use ?I mean the ranges 1 ghz like that
bharath
Postby shovenose » July 21st, 2011, 8:12 am
It looks like it supports any Pentium III.
Depending on which country you live in I may be able to send one.
I have to go to the post office anyway :-(
