by LongRunner » October 18th, 2013, 5:44 pm
Pentium wrote:They're all 820uF 6.3V. I have some poly caps that are 820uF 2.5V (Fujitsu bumblebees), I'm wondering if this is too low of a voltage. Since the DDR2 RAM runs at 1.8V will I be okay using these or is it not suitable since they're fed power by the 3.3V rail?
Measure the voltage across them in operation (if the board stays powered on even with the CPU removed, that helps). If it's indeed 1.8V, you can use them. Anything higher and you should obtain 6.3V caps.
