The purpose of firewall software?
Discuss how to keep your network safe. both on wired and wireless connections.
Postby shovenose » May 14th, 2011, 4:00 pm
Well, many routers/modems have a sort of bulilt in firewall. Also, all Windows and Mac OS X- based computers in the past 10 years have some sort of built in firewall.
So what is the purpose of a dedicated software firewall?
RE: The purpose of firewall software?
Postby Klinc » May 29th, 2011, 12:05 pm
Host intrusion. A thing avs don't have. Avs scan for signatures while firewalls follows a set of rules. A firewall is only as good as its rules set by the user. That's why they ask so much questions in the first week of install as they learn your setup and software. But once that's done they quiet down. Hips might save you one day as it can block zero day exploits and unknown stuff running on your pc without it telling you about it. Comodo firewall got a very good hips. Online armor and outpost as well and their all free
3DMARK11
Klinc
Postby shovenose » May 29th, 2011, 12:15 pm
I use Comodo Internet Security (AV+Firewall in one) mainly.
Re: The purpose of firewall software?
Postby Klinc » February 6th, 2012, 1:23 am
I use Common Sense firewall
3DMARK11
Klinc
Postby shovenose » February 6th, 2012, 7:15 am
While I usually use Avast! Free Antivurirus + Windows Firewall but right now I'm using Avast! Internet Security 20-day trial and I think that has a Firewall :)
Postby c_hegge » February 6th, 2012, 2:16 pm
Interestingly, Trend Micro Internet security no longer even has a firewall, nor does TM Titanium Internes Security.
Postby shovenose » February 6th, 2012, 4:44 pm
That's quite weird.
Return to Network Security
