Windows 7 Installer Not Showing Up
Discuss operating systems in this section. Including Linux, Mac OS, and Windows.
Postby shovenose » October 24th, 2011, 5:32 am
This is a weird one:
I pop in the Windows 7 DVD and it says Loading Files...
all normal. But then it gets to the part with the blue windows 7 background, but the installer window never shows up. It;s the ECS G31T-M7 motherboard. Might the G31 chipset not be supported?
Re: Windows 7 Installer Not Showing Up
Postby c_hegge » October 24th, 2011, 4:34 pm
I doubt it's the chipset, but probably something funny with the motherboard.
Postby shovenose » October 24th, 2011, 9:00 pm
Like...?
Postby c_hegge » October 25th, 2011, 1:18 am
Maybe the BIOS.
Personally, though, I've nerver installed 7 on a Intel _3_ chipset, but I think I have done vistrash on an Intel DQ35JO motherboard (Q35 chipset) and it worked fine.
But you know what my solution would be ;)
Postby shovenose » October 25th, 2011, 8:46 pm
Windows XP?
No, I switched to Ubuntu to get away from XP.
Nah of the 6 computers I switched to LInux in my house, 4 are back on Windows 7. I decided that even though it has its annoyances Windows is still more polished and reliable than Linux.
Postby c_hegge » October 25th, 2011, 9:23 pm
Yes, XP or linux would have been my solution.
Return to Operating Systems
