speedtest wrote:If your Internet connection is slower than you think it should be, one of the first things to do is to visit an Internet speed test site. So on that note, check out one of these Internet speed test sites and run one right now, ideally one hosted by your Internet Service Provider.an Internet speed test measures the network bandwidth and sometimes latency of your connection by using sample data files and test Web servers. You can use these ptcl speed test services to measure your download speeds and verify the Internet service provider is supplying you the expected amount of bandwidth. These tools will also help you measure the results of performance tweaking your network setup.
c_hegge wrote:Huh? The picture says 54.98mbps.
