Need Help to Build a 50W Load for PSU Load Test
RE: Need Help to Build a 50W Load for PSU Load Test
Postby shovenose » September 10th, 2011, 7:49 am
Old CPU Heatsinks would be fine.
Re: Need Help to Build a 50W Load for PSU Load Test
Postby c_hegge » September 10th, 2011, 9:30 pm
There is no 80%. It's simply Voltage x Amperage = Wattage
As shovenose said, old CPU heat sinks would be great.
You could also use PSU heat sinks, but don't attach more than 1 resistor per heat sink (and if possible, use 2 heat sinks, one on each side).
Postby Galib » September 11th, 2011, 1:08 am
OK, thanks c_hegge .
Galib
Users browsing this forum: No registered users and 7 guests
