RE: Power Supply Build Quality Pictorial/Discussion
Postby duckula » September 9th, 2011, 4:30 am
And you must like this: High Quality Japanese Made Electrolytic & Solid Capacitors.
The two big capacitors in the picture are Rubycons. The bunch of polymers look like Nippon Chemi-con.
Postby c_hegge » September 9th, 2011, 3:21 pm
Yeah. I noticed that.
Re: Power Supply Build Quality Pictorial/Discussion
Postby duckula » September 28th, 2011, 2:28 am
This PSU was pulled out of a Lenovo desktop computer. OEM is Acbel. Look at the internals of the PSU... :lol:
Postby c_hegge » September 28th, 2011, 2:44 pm
I can't see any PI coils on the secondary, so ripple could be a problem. As for the LTEC caps, they seem to do quite well in delta units, but elewhere, they are maybe a tad better than fuhjyyu, maybe on par with capxon.
Postby duckula » October 4th, 2011, 6:07 pm
Cooler Master Silent Pro Hybrid series power supplies:
http://www.techpowerup.com/153082/Coole ... eries.html
Postby c_hegge » October 4th, 2011, 7:49 pm
80+Gold with those heat sinks - should be almost dead silent.
Postby shovenose » October 4th, 2011, 8:25 pm
As Long as it's silent, just not dead.
Postby c_hegge » October 4th, 2011, 10:50 pm
you know what I mean. I'll see if I can get CM to send me one once I get my oscillosope and review the antec
Postby duckula » October 4th, 2011, 11:16 pm
PureOC has published a review for the Silent Pro Hybrid 1050W power supply.
http://www.neoseeker.com/resourcelink.html?rlid=244497
If their test results are trustable(I'm not sure about it), the ripple suppression of that unit is kind of disappoint.
(see why I'm not sure about the reliability of PureOC's review? They wrote 5.5V instead of 5V and assumed the SPH 1050W was a 1000W unit and only pulled 1000W out of it.)
Postby duckula » October 4th, 2011, 11:25 pm
c_hegge wrote:you know what I mean. I'll see if I can get CM to send me one once I get my oscillosope and review the antec
You may want to mod it if you get your hands on one. :mrgreen:
