Re: Power Supply Build Quality Pictorial/Discussion
Postby duckula » October 7th, 2011, 3:49 am
Enermax Platimax 850W 80plus platinum certified PSU. Interesting to see that Enermax soldered several capacitors on three small vertical daughter-boards. I've seen DIYers do that before, but never PSU manufacturers.
More pics:
http://www.techpowerup.com/reviews/Ener ... EWT/4.html
Postby c_hegge » October 28th, 2011, 12:49 am
It looks pretty average. The heat sinks are small, and it uses taiwanese capacitors. It does deliver it's labelled wattage, but the review never mentioned the ripple.
Postby c_hegge » October 28th, 2011, 1:31 pm
Hard to say without seeing the ripple. The corsair CX600 will deliver 600W ripple in spec, but it uses samxon GF caps, which are probably less reliable than LTEC. If you're prepared to recap it, go with the corsair, otherwise the AcBel. If I had the option, though, I wouldn't use either. I'd go with XFX, since all of their units are seasonic made and use Japanese capacitors as far as I know.
Postby c_hegge » October 29th, 2011, 2:41 am
I'd definitely go seasonic over either of those.
Postby duckula » November 5th, 2011, 9:02 pm
Innards of the Seasonic SS-1000XP 1000W 80plus platinum compliant PSU.
It originally had three big capacitors. The reviewer took one off in order to take picture for the daughterboard behind the primary capacitors.
More:
http://www.techpowerup.com/reviews/Seas ... 000/4.html
Postby c_hegge » November 5th, 2011, 9:50 pm
Reminds me of the X-series
Postby duckula » November 25th, 2011, 12:06 am
Internals of the FSP AU500FL fanless power supply. It applies a complete different topology (LLC) compared to the other Aurum's (ACF).
Disassembly:
http://www.itocp.com/htmls/29/n-3129.html
Review:
http://www.itocp.com/htmls/91/n-3091.html
Postby c_hegge » November 26th, 2011, 4:42 pm
Wow! FSP actually built a PSU with really big heat sinks. I dind't even think that was possible!
Postby c_hegge » November 29th, 2011, 7:16 pm
Thanks for the spam (not)
Postby shovenose » November 29th, 2011, 8:01 pm
LOl. I'm getting the damn image resizer fixed (hopefully) phpBB was a damn mistake... But, I got my custom phpBB style so now I can't switch back :(
Users browsing this forum: No registered users and 63 guests
