Re: Power Supply Build Quality Pictorial/Discussion
Postby duckula » March 22nd, 2012, 10:47 pm
Then I will avoid that PSU as far as possible. :P
Postby duckula » April 21st, 2012, 8:48 pm
InWin Green Me 750W PSU:
http://www.overclockers.com/inwin-green-me-750-watt
Postby shovenose » April 21st, 2012, 10:29 pm
I'm green too.
Postby c_hegge » April 25th, 2012, 6:35 pm
It's interesting how they said Brite Plus was the OEM. They are probably the PCB manufacturer, but this unit is actually made by In Win.
Postby c_hegge » May 8th, 2012, 3:29 pm
Hardware Secrets got the OEM wrong too. They said it was FSP. I had a small discussion with Gabriel about it. He asked In Win, and it turns out that it is indeed an in-house build, as I thought.
Postby duckula » May 10th, 2012, 4:16 am
Enermax NX450 PSU. It actually is a CWT inside of a Enermax. It's based on the same platform as Corsair VS450.
http://power.zol.com.cn/290/2904591_all.html
Postby c_hegge » May 10th, 2012, 7:29 pm
It looks very similar to the VS450. It even uses Jun Fu caps throughout the secondary side!!
Postby duckula » May 30th, 2012, 2:18 am
Be quiet! Dark Power Pro 10 550W
More:
http://www.techpowerup.com/reviews/beQu ... 50W/4.html
Postby c_hegge » May 31st, 2012, 2:02 pm
Looks like a new platform, or a Custom design for BeQuiet. Not that I really like those heat sinks, but on a low capacity 80+ Gold unit, there's not a lot of heat to dissipate.
Postby cbanks » May 31st, 2012, 5:34 pm
/wow this psu is a FAIL! use dynex psu from best buy for 9.99
:clap: :clap: :clap: :clap: :clap: :clap: :clap:
cbanks
