Re: Power Supply Build Quality Pictorial/Discussion
Postby shovenose » May 31st, 2012, 9:31 pm
LOL chris!
Postby c_hegge » May 31st, 2012, 9:45 pm
You beat me to it. $10 Power supplies should never be purchased or used. Read the El-cheapo power supply round up
Postby duckula » June 15th, 2012, 5:51 pm
Corsair AX1200i 80plus platinum certified PSU. :clap: OEM is Flextronics.
Postby c_hegge » June 15th, 2012, 7:23 pm
Looks a little better than the CWT ones with the finless heat sinks
Postby duckula » June 15th, 2012, 10:30 pm
Like those heat sinks in the new Corsair GS series units? :D
Postby c_hegge » June 16th, 2012, 12:31 am
Nope. I think I see Samxon GF series caps in there too.
Postby shovenose » June 16th, 2012, 6:57 am
It's odd they use a high quality panasonic capacitor in the primary where it really doesn't matter quite as much
Postby c_hegge » June 16th, 2012, 6:44 pm
With APFC, yes it does. It stresses the big cap more than the normal voltage doubler function. In fact, if a PFC Circuit is badly designed, it will kill a Panny.
Users browsing this forum: No registered users and 39 guests
