RE: Power Supply Build Quality Pictorial/Discussion
Postby c_hegge » June 6th, 2011, 7:38 pm
Probably is a 400 watter, but just not a very good one.
Postby shovenose » June 6th, 2011, 8:45 pm
Silver Stone power supplies are usually pretty decent.
Postby duckula » June 7th, 2011, 10:28 pm
Innards of the new released Corsair HX1050 PSU. It uses the similar design as the HX850.
Postby c_hegge » June 7th, 2011, 11:39 pm
Can you hear me corsair? STOP USING THOSE FINLESS HEAT SINKS!!!!!!
Postby duckula » June 8th, 2011, 12:22 am
lol. Actually, they use these plate heatsinks more and more in their recent products.
Postby duckula » June 12th, 2011, 3:42 am
In Win Commander II 1200W. OEM is Andyson. Topology: double-switch forward+DC-DC converts for +3.3V&+5V+synchronous rectifying. Two big capacitors are from Panasonic(HC series), which are rated at 400V 105℃. Capacitors on the secondary side are from cheapo teapo.(sc series).
http://www.anandtech.com/show/4425/in-w ... ii-1200w/1
Postby c_hegge » June 12th, 2011, 11:15 am
It's odd that they would use andyson as the OEM. In Win usually build their own units.
Postby shovenose » June 12th, 2011, 12:44 pm
are we sure it's Andyson?
Postby duckula » June 12th, 2011, 2:40 pm
Postby shovenose » June 12th, 2011, 2:54 pm
OK. Yeah I never doubted you lol
Users browsing this forum: No registered users and 61 guests
