Postby duckula » March 28th, 2011, 5:57 am
Note: This thread was originally posted on CPSRF by shovenose. ;) And this is one of my favourite threads. Since shove doesn't have time to transport it from CPSRF to here, I think perhaps I can do it for him.:D
Please post pictures of PSU innards here.
I'll start with a PCB shot of the Seventeam ST-650PWL power supply to show you just how ugly can a PCB be! Read the full review here, if you fancy. This is the same platforum as the coolermaster GX650.
RE: Power Supply Build Quality Pictorial/Discussion
Postby shovenose » March 28th, 2011, 7:14 am
thanks duckula!
by the way, your post says
shove does have time
, im not sure if you wanted that :P
Postby duckula » March 28th, 2011, 7:19 am
Thanks Michael. lol I meant "doesn't". :lol2:
Postby duckula » April 23rd, 2011, 12:14 am
Antec's planning on replacing BP series with VP series and they just added a new model into their VP line-up. Yep, it's Delta (the Delta mark on its transformer is a giveaway) again and currently it is listed on 360buy (an equivalent of Newegg in China) for RMB269 yuan(approximately US$41). It's 230VAC only.
Image[hr]
I'm excepting someone shoots antec with rapid fire machine gun. :D(That's in jest)
Postby c_hegge » April 23rd, 2011, 1:37 am
LTEC Caps... Antec just won't learn their lesson
:rapidfire: antec (as Duckula predicted)
btw, the soldering on that seventeam looks a lot like my soldering.
Postby duckula » April 23rd, 2011, 1:53 am
So you are on par with Seventeam in term of soldering. :D
Postby c_hegge » April 23rd, 2011, 2:40 am
Vantec Ion2+ 620W. looks a bit like an old school half bridge design with that big grounding wire coming from the transformer. The caps are all panny FC, although that's because I recapped it. originals were a mix of Jun Fu and el-cheapo teapo. Not sure, but I think Andyson is the OEM
It was powering my main rig untill it failed and was replaced with my re-built rexpower 400W and later an In Win power man 600W (80+ Bronze with apfc)
Postby shovenose » April 23rd, 2011, 6:00 am
Are you gonna either fix it or reuse the caps?
It looks decent, but the heatsinks remind me of a raidmax!
Postby duckula » April 24th, 2011, 11:18 pm
FSP Aurum 500W power supply. :lol: at the secondary heatsink. There's one good capacitor (primary cap, hitachi) with a bunch of junks caps. (the rest except the primay one. Crapxcon). The main topology used on/in (help me decide which preprosition I should use, thanks:D) this unit is Active Clamp Forward.
Postby c_hegge » April 25th, 2011, 3:13 am
Antec SU-380. Removed from a Solution series case with bad caps (Only Some Trash) and recapped with panny FC. Some of you may recognise this from CPSRF, but since I re-capped it, I can't accurately test the ripple. OEM is seasonic. It has beefy heatsinks and good silicon, but let down by the caps and the death ADDA.
Users browsing this forum: No registered users and 27 guests
