Need Substitution Number of a PWM IC
Postby Galib » April 7th, 2012, 9:54 am
Hi,
I got 7 Power supplies for repairing . I have repaired 6 Power supplies successfully . But I could not repair One Power supply due to it's PWM Problem . But it's IC is totally uncommon !!! The IC number is LPG-899 . It is 16 DIP IC . I am not finding the datasheet of this IC anywhere nor finding the new IC in my local market !!
Can you give me the Datasheet and Substitution number of this IC which is available in the market .
Thanks
Galib
Re: Need Substitution Number of a PWM IC
Postby c_hegge » April 9th, 2012, 4:32 am
Some manufacturers (including Linkworld and FSP) often use non-standard PWM ICs. Unfortunately, they don't publish the data sheets on them, nor do they sell them to electronics suppliers. The LPG___ model on the IC sounds like it could be a propietry linkworld IC. Can you get a picture of the Internals?
If the PSU is really a linkworld, though, do the computer a favour and hit the power supply with a sledge hammer. I've heard of those things delivering over 3V of ripple on the +12V rail (where the limit is 0.12V) and 1.3V on the 5V rail (where the limit is 0.05V), which is more than enough to damage attached hardware.
Users browsing this forum: No registered users and 30 guests
