keys on the keyboard that have never been used
Postby duckula » March 18th, 2011, 7:25 am
Are there any keys on keyboards that you have never used? As for me, there are two. They are "scroll lock key" and "pause/break key". And I don't even know what the "scroll lock key" is for. :lol:
RE: keys on the keyboard that have never been used
Postby Kong » March 18th, 2011, 8:03 am
Neither do I. For me, I never use "`", "scroll lock", "pause break", and those additional keys that are added at the top of the keyboard.
Kong
Postby c_hegge » March 18th, 2011, 4:12 pm
Just Scroll lock for me. I do use the Pause/Break key in flight sim X (that's how you pause the game).
Postby shovenose » March 18th, 2011, 4:31 pm
i thought that P was pause in ms flight sim?
Postby c_hegge » March 18th, 2011, 5:18 pm
P or pause/break. both do the same thing.
Postby duckula » March 18th, 2011, 6:19 pm
Then we have come into a common sense that "scroll lock" is the most useless key on the keyboard. :lol:
Postby Kong » March 19th, 2011, 4:57 am
Don't forget those useless additional keys located, usually, at the top of the keyboard. ;)
If I press one of them, I get the "Page Cannot Be Found" error. :lol2:
Kong
Postby shovenose » March 19th, 2011, 7:13 am
on my laptop, there is this big blue button above the keyboard, its bigger than the power button. "ACCESS IBM". but since i didnt use the oem IBM version of Windows, it doesn't do anything :lol:
Postby duckula » March 19th, 2011, 9:55 pm
Kong wrote:Don't forget those useless additional keys located, usually, at the top of the keyboard. ;)
:blush:Yeah, most of those additional keys are useless, except the volume up/down key or knob. My old keyboard has a volume knob on it and I found it pretty convenient.
Too pity that after I had sprayed water on my old keyboard for several times, it got so annoyed and decided to leave me.:s
And the current one is a cheapo HP keyboard, it doesn't have any additional keys on it.
Postby RWenger » April 21st, 2011, 10:26 pm
My laptop has a scroll lock key that turns the numpad on or off. My numpad is on the right hand side of the keyboard with 1-9 being jkluio789 on the keyboard. Normally you would have to press FN and the appropriate key, but with the scroll lock on you can type away.
RWenger
Users browsing this forum: No registered users and 64 guests
