- The only way for mains outlets to be child-safe (aside from placing them out of their reach) is for them to have internal shutters blocking the insertion of foreign objects into the power-carrying contacts; the idea that plug-in covers will provide protection is nothing more than wishful thinking, at least with flush-mounted sockets. If the plastic they are made of is brittle, they can also snap their pins (especially with thin flat pins as on the Australian and North American plugs), leaving them in the socket and rendering it unusable.
- I have no idea who thinks it's OK for the same old plug/socket system to remain in use in North America. Bare live and neutral pins only a few millimetres from the edge of the plug are not safe enough, nor are extension-cord sockets that make it easy to misinsert the plug in such a way that one of the power pins is in the slot with the other hanging off the side and waiting to zap someone (by way of the current passing through the appliance). What's even worse is that some Japanese power cords have a very similar 2-pin plug, plus a separate earth wire exiting from the plug with a fork lug on the end, that must be manually attached to a binding post in the outlet…
- The old incandescent lamp sockets are also of great danger to those who insert their fingers into them. Personally, I think they should have been banned and replaced with something safer decades ago, but people have just too much resistance to changeover.
- Adding insulating sheaths to the thin flat pins on Australian plugs has, rather noticeably, worked against their mechanical strength, and bending the pins too far can break the insulation (which is usually, if not always, a hard plastic) off. Then again, I guess that's just what happens when you add a safety feature on as an afterthought…
- In terms of physical construction, the sheathed unshielded mains cables could be said to be Class II (double-insulated), and shielded flexible cords (seldom-used, but I have a few) would be Class I (as the shield is earthed). I don't want "figure-8" (e.g. SPT) cable on the mains, as only one insulation layer between the mains and the outside world is just asking for trouble, at least in my view.
Additionally, I have seen the sheathing on light-duty flat cord occasionally fail at strain points. Permanently attaching any mains cord to an expensive item is not sensible, nor is permanently attaching a light-duty mains cord to anything (IMO). Unfortunately, many CRT TVs did attach a light-duty flat cord directly to the set, and not just the small ones, either. Personally, I think that light-duty cord is only just acceptable with the small IEC sockets (C1 with tinsel-wire, C5 and C7 with normal wire). - To guard against overloading, a cord with a socket at one end should use cable with at least the current rating of the socket, and if the combined current rating of multiple sockets exceeds the rating of the main plug, a circuit breaker (or otherwise fuse) with the rating of the main plug should always be used. In Australia for example, normal power outlets (and most extension cords) are rated to 10A, but power circuits generally have 2.5mm² cable and 16A MCBs; power boards/strips here contain a 10A circuit breaker, but doublers are usually unprotected, so can overload extension cords with ease if abused. I believe the system used in much of Europe is that both MCBs and outlets are 16A, and extension cords there (whether single- or multi-way) are built to carry all of that.
- The problem with the "Schuko" plug/socket used in much of Europe, aside from not distinguishing between live and neutral, is that Schuko plugs will fit into various sockets without making the earth connection. The somewhat similar system used in France among other places with an earth pin in the socket only allows the plug to fit one way, but the actual polarity is not consistent, so it might as well be unpolarised anyway.
And, of course, there's that death-trap presented by the Y1 capacitors in most Class II switching supplies to signal circuitry…
