LongRunner's round-up of the World's Worst Companies!
Postby LongRunner » November 17th, 2014, 2:51 am
We all have our low points, from time to time. But these are the companies that have managed to fuck things up in ways that just about no-one else could do if they tried. Don't buy anything from the companies on this list — you will regret it much more likely than not. So brace yourselves for…
  • Apple takes the top "prize", for having become a complete monster in every way. Not only that, but they're the only company I know of to fail to enforce correct safety earthing of their notebook chargers (as was discussed before).
  • Brilliant Lighting of Australia has been anything but; aside from that rather worthless LED floodlight I mentioned in the backronym thread, a fluorescent lamp that was used mainly by my sister discoloured its plastic from purple to blue Image, and the ballast got so hot that the insulation on its lead-in wires (which was irradiated PVC with a temperature limit of not the usual 75°C for flexible cords nor the now-common 90°C for fixed mains cables, but 105°C) broke down in short order. I doubt if they even have any actual engineers to be honest…
  • Creative Labs of former SoundBlaster fame lost the plot when they transitioned from ISA to PCI sound cards, and they have since screwed up pretty much everything that could conceivably be screwed up.
  • The Australian electrical company HPM has, to be honest, sold Hopelessly Poorly Made garbage for quite a while now: The cord grip on their model 7P extension-cord socket doesn't even work with the cable type it was allegedly designed for, the plastics they use are about as tolerant of UV exposure as IBM's Deathstar 75GXP was of thermal cycling (I have two 6-way HPM power boards/strips that have severely discoloured in less than 5 years of household usage; clearly, they can't even dream of having the centuries of lifespan that I would predict from high-quality electrical accessories), they have yet to adopt the logical surround system of Clipsal's ever-popular 2000 Series, and they seem to think 32A is safe for the highest-current variant of the Australian 3-pin plug (there are two problems with that — reliable operation at that current would IMHO require nickel-plated contacts, which they don't use, by mandate; more on that later — and circuit breakers above 20A, the most powerful variant of the plug made by Clipsal, will not adequately protect the smaller cables from short-circuit events). Overall, they're pretty much the Australian electrical industry's exaggerated version of STMicroelectronics (or Infineon); by now, you would have to pay me to take one of their products, and even then, I probably wouldn't use it (I still have a few HPM products remaining in use but intend on replacing them as soon as I get the opportunity) – the only exception is their model 5M cordline switch, but only because nothing better is available here.
  • Seagate also deserves mention for losing the plot starting around 2005. Back in their glory days (Barracuda ATA III/IV/V/7200.7), their drives were reliable, consistent with HDA configurations, and had at least competitive performance; but ever since then, they've gone downhill. The 7200.11 deserves special mention for being not only unreliable, but also for the name spanning two whole generations of drive (codenamed Moose [250GB/platter] and Brinks [375GB/platter in the 1.5TB model and 333GB/platter in the smaller models]), both of which had 1TB models (ST31000340AS and ST31000333AS respectively), with their unreliability as the only commonality Image; by all reason, Brinks should have been called the 7200.12 and its successor (codenamed Pharaoh) the 7200.13. And of course the 7200.14 (Grenada) was a full-on successor to the IBM Deathstar 75GXP.
  • Sony has many haters, in no small part due to their draconian attempt at copy protection of music CDs — even at the cost of ruining PC users' Windows installations. Not that the company is that good at what else they do, either.
  • Telstra Bigpond is, considering their nightmarish support, ridiculous prices, and unreliable hardware, undoubtedly the worst ISP in Australia — do I really need to say more?
  • VIA's stuff has, in my experience, proven unreliable in the long term, and it was evidently a big mistake, in hindsight, for AMD to have left VIA to make the chipsets for the Athlon/XP/64 families.
I have noticed that almost every Asian-made mains cord (and every external PSU) in my stash has nickel-plated plug pins, while their Western counterparts still consider non-plated brass "good enough". The difference the nickel plating makes is easy to underestimate: The oxide layer that forms on bare brass from early on can add as much as 0.1Ω to the circuit for each pin (as measured by my DMM), while nickel-plated contacts add negligible extra resistance (even after decades of use). Presently, nickel plating is still unusual for the socket contacts — mainly because the plug pins can be touched by the user when unplugged and the socket contacts can't. (Have you ever noticed how mains connectors near their rated load always seem to get much warmer than the cables between them? This is one of the reasons. Without a rule to mandate nickel plating, I think that the 32A and maybe 25A plugs and sockets that HPM makes are, quite frankly, fire hazards in the long term.) But at least Clipsal try to make good products, unlike HPM who are all show and no go nowadays.
Last edited by LongRunner on December 20th, 2024, 4:37 pm, edited 1 time in total.
Reason: Pruned some inaccurate parts
Re: LongRunner's round-up of the World's Worst Companies!
Postby LongRunner » November 18th, 2014, 8:09 pm
HPM did appear to make high-quality products in the distant past, so I suppose they're not unlike Seagate in the direction they've turned in. This page of a museum of electrical items, at least, shows (in photo #8) a 1950s-era HPM single outlet apparently still in good condition (setting aside the comical backwards N).
But after all they've done in modern times, I absolutely cannot forgive them.
Frankly, I'm getting rather tired of the overdoses of FLA (Frivolous Lawsuit Avoidance — otherwise known as "ass-covering"), as I know that the standard Australian-type extension cords (with a single socket of the same rating as the plug) are extremely reliable provided they were properly made in the first place and aren't overheated (be that due to exceeding the maximum load — whether with outright illegal contraptions or the common OCP-less 2-way adapters mentioned — and/or operating the cord heavily coiled-up).
Last edited by LongRunner on December 20th, 2024, 4:39 pm, edited 1 time in total.
Reason: Pruned some inaccurate parts, updated museum link
Postby c_hegge » November 18th, 2014, 9:04 pm
A-Power, Fuhjyyu, GSC/Sacon. I imagine they probably belong on the list.
Microsoft is kind of up there, too. They've just about ruined windows and office.
Postby LongRunner » December 8th, 2014, 10:41 pm
c_hegge wrote:A-Power, Fuhjyyu, GSC/Sacon. I imagine they probably belong on the list.
Yes, indeed.
Let's not forget the incident involving weak mounting of the power inlets in the PSUs of some of the original Xboxes — which therefore moved around when connecting/disconnecting the cord, eventually resulting in broken solder joints and arcing. So did Microsoft take the consoles back for repair? No — too expensive :( Instead, they recalled the power cords that came with the affected consoles, replacing them with cords with built-in Arc-Fault Circuit Interrupters (are those devices even used outside of North America?). That may have succeeded in preventing subsequent house fires, but didn't actually fix anything.
Postby Wester547 » December 10th, 2014, 5:23 pm
GSC/Sacon is the worst....
Fixing that problem would have been very easy. They wouldn't have even needed to have resoldered it more effectively, all they needed to do is mount it such that the inlet could have been screwed to the chassis like with regular ATX PSUs and it never would have been a problem unless someone unscrewed and screwed the inlet too many times....
Haven't been too happy with AVC lately. I've pulled countless seized hydraulic bearing fans and a brand new C7015T12MY fan was working fine but was making unusual noises every 2 seconds, a noise that could easily be mistaken for the read/write heads of a HDD seeking (and a noise that made it difficult to hear the HDD seeking). I took the fan apart (it had an adequate amount of lubricant) and found no signs of damage, rusting, or charring, but would guess that either the ball bearing is somehow damaged or the impeller is imbalanced in that unit. It's the first C7015T12MY I've come across to sound like that, though....
Postby LongRunner » December 10th, 2014, 7:18 pm
Wester547 wrote:Haven't been too happy with AVC lately. I've pulled countless seized hydraulic bearing fans and a brand new C7015T12MY fan was working fine but was making unusual noises every 2 seconds, a noise that could easily be mistaken for the read/write heads of a HDD seeking (and a noise that made it difficult to hear the HDD seeking). I took the fan apart (it had an adequate amount of lubricant) and found no signs of damage, rusting, or charring, but would guess that either the ball bearing is somehow damaged or the impeller is imbalanced in that unit. It's the first C7015T12MY I've come across to sound like that, though....
Are JMC/Datech still worse?
I suppose PC Chips also deserves a mention, for producing the infamous mainboards with fake cache.
Postby Wester547 » December 10th, 2014, 7:37 pm
LongRunner wrote:Are JMC/Datech still worse?
Yes, because even their dual ball bearing fans have a very finite life (though they don't have any plug but neither do those same NMB fans with far more lubricant and I seldom see them fail).
Postby LongRunner » January 9th, 2015, 1:53 am
Whoever made this thing also qualifies for sure. :D :eek:
Postby LongRunner » January 19th, 2015, 8:40 pm
See for yourself:
The one at the top is in (more-or-less) like-new condition. The one below is after maybe 4 years worth of use. It was near a window but still…(part of another unit has discoloured about as badly just from the room lighting).
HPM power-boards (front).jpg (81.56 KiB) Viewed 28835 times
HPM power-boards (back).jpg (77.08 KiB) Viewed 28835 times
There are also a few Clipsal outlets near windows. Those haven't discoloured — only the red "on" marks have faded (that happens to most red dye, in my experience). But I have seen discolouration of very old Clipsal stuff (in other buildings) so it seems to me that as Clipsal improved, HPM got worse…
Users browsing this forum: No registered users and 43 guests
