OK so it's the same, incl. the secondary side hack
Which I think also depends on benevolence of the control organ…
Anyway, next question then is, how one becomes an electrician in AU? Here it is stupid, you have to have certain education from given list AND do qualification tests and also have practise, otherwise no luck. Without the right education, no matter if you do the qualification test 100 times, you are still screwed. Just great as the list is fixed for like 50 years. Guild system in 21st century?
Are there more reasonable conditions, like having some qualification course for half a year or a year, then some test and voila, you got it? Because ATM, I have applied for electrician class in high school (man don't even ask) and should start from September this year. So the question is whether it is ± the same there, so it would be better for me to get papers here and then do some differential tests, or to skip everything here and go study directly to Sydney.
