What do you think about my sillt 404 page
Discuss general internet stuff here. You can also talk about websites, etc.
Postby shovenose » June 2nd, 2011, 6:14 pm
I will make this the 404/403/500 error page here too if you think it's good.
Take a look...
just go to shovehost.com/apagethatdoesntexist or click the link below
http://shovehost.com/erhgejrgejyrgfjykergfkuregf
Feedback?
RE: What do you think about my sillt 404 page
Postby Morsec0de » June 3rd, 2011, 6:39 am
That's a bad 404 page. 404 pages, in my opinion, should be at least a little bit helpful, and that doesn't look professional at all. If people are to take you and your site seriously, you should consider getting something that does look more serious. Some people won't know what 404 means, you should at least specify 'Page not Found'.
An example of a good 404 page is the one over at Hack Forums. http://hackforums.net/page
- It specifies the page wasn't found.
- It has a search field to try to navigate around.
The graphic isn't too bad though. :)
Morsec0de
Postby shovenose » June 3rd, 2011, 11:50 am
I was trying to get into the sillier approach. I might at least include a link to the main site lol...
This is the best 404 page ever (click the animal)
http://blippy.com/404
Postby Advertise4you » June 3rd, 2011, 1:58 pm
how do i put that error im looking for that plugin long time now:S
[align=center]Image[/align]
Advertise4you
Postby shovenose » June 3rd, 2011, 3:50 pm
Can you please rephrase what you just said in a way I know what you're talking about?
Thanks:P
Postby Morsec0de » June 4th, 2011, 12:30 am
Advertise4you wrote:how do i put that error im looking for that plugin long time now:S
It's not a plugin. You can do either of the following:
1) Go to cPanel --> Advanced --> Error Pages --> 404 (Not found).
2) http://lmgtfy.com/?q=How+to+insert+a+40 ... my+website
Morsec0de
Postby shovenose » June 4th, 2011, 6:11 am
I'm not using cPanel. But the process was similar.
Postby shovenose » June 4th, 2011, 6:13 am
I will change my 404 page maybe later to something a little more informative...
but one of the most visited websites on the web has a 404 page like mine...
http://www.google.com/404
Postby Morsec0de » June 4th, 2011, 11:22 pm
shovenose wrote:I will change my 404 page maybe later to something a little more informative...
I actually thought Google would be more professional. Look at the title...
Error 404 (Not Found)!!1<
Morsec0de
Postby shovenose » June 5th, 2011, 8:52 am
Return to General Internet/Website Discussion
