Our Power Supply Testing Methodology
Re: Our Power Supply Testing Methodology
Postby c_hegge » March 7th, 2013, 5:31 pm
Usually, they are allowed to warm up until the power draw stops climbing (which usually takes 2-3 minutes), and they are run at each load for around 10 minutes. I don't currently use a thermometer, but above 500W load, the PSU's intake grill can start to feel quite warm, so around 40*C is probably about the intake air temperature.
Postby LongRunner » October 18th, 2013, 12:55 pm
When are you going to update this article to cover the new load tester???
The power draw meter also has the ability to measure the power factor, which is what it appears to be drawing compared to what is is really drawing. It is presented as a decimal number between 0 and 1. For example, a device with a power factor of 0.5 is really only drawing 0.5 times (or half) what it appears to be drawing, so you will pay for twice the amount of power you really are using. Of course, the closer that number is to 1, the better. By nature, switching power supplies often have a low power factor.
Explain what apparent power is (RMS volts x RMS amps, but in a way that someone new to electronics would understand). Homeowners are only billed for real power, though.
The drawback is that as [resistors] get hot, their power draw goes down.
In the specifications for Stackpole KAL series (presumably that or similar aluminium-cased power resistors are used), the temperature coefficient for values of 0.1~9.9Ω (higher values are better) is ±50ppm, giving a potential variation of ±1.25% from 25°C to the operating limit of 275°C, which doesn't sound like a big deal to me. (By the way, what is the tolerance of the resistors you used??? Anywhere from 0.1% to 5% is available in that series.)
The WCB series of axial leaded ceramic cased wirewounds is as good in that regard. RNF (metal film) comes in ±10/±25/±50/±100 (the better ratings being unavailable in low values). Carbon-based resistors are the real suckers but their temperature coefficient is negative - Stackpole states -400ppm for CF series in 10Ω~9.99k; this time higher values are worse, except for <10Ω which are ±400ppm (why both ways???) - which would result in increasing power draw. (RNF and CF can only withstand 155°C, though.)
I'm pretty sure a load tester could be made quiet to even 900W, without using ludicrously large fans (I'm thinking dual 120mm, as used on both the old and new units here) or putting the resistors in danger, and even in a hot environment, as long as a fair temperature gradient was allowed between intake and exhaust. (NMB says that 1.76CFM of flow gives a temperature rise of 1°C for each watt dissipated, so you could get away with 76.3CFM at 1300W allowing a 30°C rise (which in a PC would be unacceptable, but in a load tester it should be fine, as long as you're careful with the hot air :D).)
Postby c_hegge » October 21st, 2013, 4:45 pm
HWI is getting a new room next month, and I also plan to try replacing the load tester's power meters (the ones I use now don't work accurately below 12V, and they are easy to kill). The article will be updated once that happens.
The toad tester uses mostly Arcol HS50 series resistors. They are 5% tolerance, with a 100ppm temperature coefficient, but I have left the fans off before at light loads, and I haven't noticed a drop as they warm up. The new tester does use quieter fans than the old one. It's still a bit on the loud side, but compare this video with the old tester to this video with the new tester, and you can see that it is much quieter. I may try it with even lower speed fans once I get the new meters for it.
Postby LongRunner » October 21st, 2013, 10:28 pm
c_hegge wrote:The toad tester...
:lol2:
Given that those resistors can only withstand 200°C (not the 275°C of the Stackpole ones), the maximum variation with them is 1.75% from at 25°C.
Postby c_hegge » October 21st, 2013, 11:17 pm
The spell check didn't pick that one up :lol:
