Be Quiet! Dark Power Pro P11 550 W: from gold to platinum
Re: Be Quiet! Dark Power Pro P11 550 W: from gold to platinu
Postby powernod » April 13th, 2016, 6:02 am
Posted by Behemot
Trying to interrupt the power for 19.4 ms revealed that the hold-up time is slightly less, as can be seen on the image with the waveforms combined. It was 19.1 ms. This is still within specification but probably the lowest value so far.
So, if i can understand correctly, you mean that while "Hold-UP time" was 19.4ms, the "Power_OK signal" was 19.1ms? :huh:
Mobo:Asrock 939a785g
cpu cooler:ArcticFreezer13 CO
GPU:Asus 750 Ti 2GB
RAM:4 GB DDR 400MHz
PSU:Seasonic Platinum 660
Tower:Coolermaster Elite 430
Oθόνη: Asus VE228HR
OS:Windows 7 64bit
powernod
Postby Behemot » April 13th, 2016, 8:43 am
Voltage HUT, at that time I was not yet measuring the PG signal HUT. When I interrupted the power for 19.4 ms, the HUT dropped a bit, that's all.
