Antec SU-430 review
Antec SU-430 review
Postby c_hegge » July 11th, 2011, 1:58 am
RE: Antec SU-430 review
Postby Th3_uN1Qu3 » July 11th, 2011, 2:16 am
That... on a Seasonic built unit... me no like. :(
Th3_uN1Qu3
Postby shovenose » July 11th, 2011, 5:39 am
@The_Unique yes it's a disgrace to Seasonic.
@c_hegge wonderful review!
Postby duckula » July 11th, 2011, 5:16 pm
:rapidfire: su-430
Postby shovenose » July 11th, 2011, 5:50 pm
Lol. I knew somebody was going to :rapidfire: Antec sooner ot later
Postby duckula » July 11th, 2011, 5:57 pm
I :rapidfire: su-430, you :rapidfire: antec. lol
Postby c_hegge » July 11th, 2011, 6:07 pm
you guys stole my line. :rapidfire: antec is usually my line. :P
Re: Antec SU-430 review
Postby Wester547 » April 10th, 2013, 1:31 pm
I know this is really long in the tooth, but.... if this doesn't have dual +12V rails then how did you get separate ripple/noise measurements (and voltage regulation results) from each +12V rail in the load tester? :O
Last edited by Wester547 on September 11th, 2013, 3:11 pm, edited 2 times in total.
Postby c_hegge » April 10th, 2013, 4:58 pm
My guess is that one connector might have had slightly better contact than the other. The same thing often happens to others too (see http://www.hardwaresecrets.com/article/ ... iew/1752/9 for example)
Postby steenss » October 4th, 2013, 8:56 pm
When I upgraded my HTPC (Antec Fusion/SU-430 PSU) I noticed the missing 12V Pi filter & installed a suitable ferrite coil. The nearby 1000uf 16v 10mm OST RLS was replaced with an 8mm Rubycon MBZ for a bit of space.
Click to view full-sized image!
steenss
