The el-cheapo Power Supply round up
Postby c_hegge » December 31st, 2011, 3:12 am
http://hardwareinsights.com/the-el-c ... ound-up-2/
Sorry for not getting shovenose to QC it, I just wanted to get it out the door before 2011 was up.
Re: The el-cheapo Power Supply round up
Postby shovenose » December 31st, 2011, 8:21 pm
Haha no problem. :) Awesome article/review and happy new year!
Postby LongRunner » May 28th, 2013, 11:51 pm
Although I don’t really know that these units sell for
Care to fix that?
Also, why not add "label doesn't add up" as one of the cons on the Hairong page??? :D
Postby c_hegge » May 29th, 2013, 3:18 pm
Care to fix that?
Done
LongRunner wrote:Also, why not add "label doesn't add up" as one of the cons on the Hairong page??? :D
Because it doesn't affect the performance.
Postby LongRunner » August 28th, 2013, 8:42 pm
...so it’s little wonder I burned the 5V rectifier out by loading it to 250W.
What load did you put on the 5V rail to make it blow??? Just curious if the rectifier met its rating...
Postby c_hegge » August 28th, 2013, 9:58 pm
I can't remember, as it was almost two years ago. In all likelihood, though, it would have been at least 15A (its rating).
Postby LongRunner » September 30th, 2013, 6:29 am
This fan sounds much louder than the one used in the Sun Pro, which is odd since they both have the same part number, but also alarming since the ATX-550W was loud enough, although this is probably why it was able to deliver a bit more power and why the capacitors are still alive.
Actually, that unit also had a bigger transformer (EI-40, whereas the Sun Pro-branded unit had an EI-33) and better ventilation.
Postby LongRunner » October 23rd, 2013, 7:06 pm
On the Hairong page:
Several minutes into Test 4, the power draw suddenly skyrocketed. It hit about 460W (about 68% efficiency) and then and then the unit went kaboom.
Postby c_hegge » October 23rd, 2013, 8:11 pm
Fixed
Postby Wester547 » November 27th, 2013, 3:07 am
I wonder how the Besta achieved 80% efficiency all the way up to 350W given how it's built. I know it was tested at 230V, but even then...
