I would have, except that it doesn't run on some older PCs. IDK why, though.Th3_uN1Qu3 wrote:No IntelBurnTest? I'm disappointed. You should use that instead of Prime.
I know. I doubt it's worth the trouble of modding it, though, considering that good electrolytics are cheaper and will still last for ages.Th3_uN1Qu3 wrote: with the PSUs you probably confused the controller pretty bad. It can be made to work with changes in the feedback loop, but it's clear that poly modding a PSU by itself without any regard to other components, will not work.
c_hegge wrote:I would have, except that it doesn't run on some older PCs. IDK why, though.
c_hegge wrote:Ah, that may be it. I didn't install .Net framework on them. I would have expected it to give a more precise error message if that was the problem. All I got was "The application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem".
These power supplies are very common in Compaq and HP branded computers, and I often run into them with a failed 5Vsb capacitor, which prevents the unit from starting. They usually use Teapo capacitors throughout the secondary side, although I occasionally come across units with LTEC capacitors. They use four 2200µF 16V (two on the 12V rail, two on the -12V rail), four 2200µF 10V (two on the 3.3V rail, two on the 5V rail), a 1000µF 6.3V and a 470µF 6.3V capacitor (both on the 5VSB rail).
5Vsb Filtering 1 1000µF 10V Teapo SC
1000µF 6.3V Nichicon FPCAP L8
5Vsb Filtering
1 470µF 10V Teapo SC
470µF 6.3V Sanyo OS-CON SEP
Users browsing this forum: No registered users and 5 guests
