In Win Power Man IP-S400EQ3-2 Review
Postby c_hegge » November 9th, 2012, 3:16 pm
Re: In Win Power Man IP-S400EQ3-2 Review
Postby shovenose » November 22nd, 2012, 10:29 am
Nice review like usual ;)
It's a bit of an improvement over the previous one which is rare. Usually newer versions of stuff get worse not better.
Postby c_hegge » November 22nd, 2012, 12:44 pm
I'm going to re-test it later after a few refinements to my teating gear. I did find those efficiency numbers a bit high, even for 230V.
Postby shovenose » November 22nd, 2012, 5:00 pm
ok so you have to do all of your reviews over??
Postby c_hegge » November 23rd, 2012, 12:07 am
Nah, just this one. Sometimes, PSUs are just good at fooling all but the best meters, and I suspect that's what happened here. My Watts Clever meter is fine and usually quite accurate for most PSUs, but you just get the odd one like this that could fool it.
Postby fincoder » January 26th, 2013, 2:56 am
The cheapest I can find these in Australia is $53 - $58 from online retailers. I assume they are still good value at these prices, do you agree c_hegge?
fincoder
Postby c_hegge » January 26th, 2013, 1:22 pm
Yes, I do. They've gone up since I wrote the review, but they are still a good option.
Postby Merman » January 26th, 2013, 8:03 pm
You can't ask for more from a $50 PSU though I thought the Adda fans were good quality.
Merman
Postby c_hegge » January 26th, 2013, 10:05 pm
Their Ball Bearing fans aren't too bad, but I've seen several ADDA sleeve bearing fans lock up and the PSU cooks itself. Many other users have reported this issue with Seventeam built CoolerMaster PSUs, which used ADDA fans. They don't have to use SanAce on a $50 PSU, but even Globe Fan or Yate Loon sleeve bearing fans usually hold up better than ADDA.
Postby shovenose » January 26th, 2013, 10:33 pm
Adda fans run well but I've seen them seize up a lot too.
