In Win Z583 Case Review
Postby c_hegge » June 10th, 2013, 10:33 pm
http://hardwareinsights.com/in-win-z583-case-review/
Bonus points go to anyone who can spot my repair to the motherboard :D
Re: In Win Z583 Case Review
Postby LongRunner » June 11th, 2013, 2:27 am
Don't the polys on Vcore look a bit small???
Postby c_hegge » June 11th, 2013, 2:30 am
Nah, there's plenty more of them under the CPU Cooler. That wasn't what I did, though.
Postby LongRunner » June 11th, 2013, 2:41 am
My only other guess is that you replaced the caps at VRM input.
Postby c_hegge » June 11th, 2013, 2:47 am
Nope. Caps are all original. If you look very carefully near the Audio header, you may note that the Ethernet controller is missing (as well as some heat discolouration). It failed and shorted internally after a lightning strike, and the board wouldn't POST. After removing it with my hot air gun, the board came back to life (albeit without the onboard Ethernet working).
Postby Pentium » June 11th, 2013, 2:29 pm
Nice review! Those are nice cases. I've built about 150 computers in them at work. Although the PSU's we get in ours are the IP-S400Dq3-2
Postby c_hegge » June 11th, 2013, 3:13 pm
The DQ3-2 variant is 80plus certified, so that's cool if you get those.
I also use those cases a lot when building PCs (usually, I use either them or the EM-035).
