....The fan is a Yate Loon sleeve bearing part. Rather than oil, the bearing has thick grease. This is much less effective, as it often gets pushed out of the bearing over a few years and doesn’t flow back in.
Do you mean that every Yate Loon and ADDA sleeve bearing you've come across uses grease instead of oil for the lubricant?c_hegge wrote:I've seen a few Yate Loon sleeve bearing fans get noisy and fail where all of the grease was on the end of the shaft and washer, and not in the bearing where it should have been. Probably not as many as ADDA, but it does happen.
c_hegge (on Badcaps.net) wrote:The case itself is one of the flimsiest I've picked up in a long time...
