Not really... Hyprobearings aren't fluid dynamic bearings, at least not from ADDA, they're just modified sleeve bearings. I have had many 45mm and 52mm ones fail on very old Radeon and GeForce graphics card the same way ADDA sleeve bearings fail (and soon after found no lubricant at all in the bearing). But if the fan spins so slowly at low loads it might have no problem lasting.The fan is made by ADDA, like on all of the other In Win products I have reviewed. This time, however, it uses ADDA’s Hypro bearing – a type of fluid dynamic bearing – as opposed to a plain sleeve bearing. These types of bearings are great, as they are quieter than ball bearings, but more reliable than sleeve bearings.
So your view of Teapo has changed?The secondary side capacitors are all made by Teapo. They aren’t as bad as the likes of Fuhjyyu and can hold up OK if given good cooling.
Wester547 wrote:Not really... Hyprobearings aren't fluid dynamic bearings, at least not from ADDA, they're just modified sleeve bearings. I have had many 45mm and 52mm ones fail on very old Radeon and GeForce graphics card the same way ADDA sleeve bearings fail (and soon after found no lubricant at all in the bearing). But if the fan spins so slowly at low loads it might have no problem lasting.
Wester547 wrote:So your view of Teapo has changed?
It didn't burn your fingers, though? Since too hot to touch could either mean above 60*C or above 70*C (discolorating and the point where it burns your fingers). And that secondary heatsink could definitely be leaps and bounds better.c_hegge wrote:It's also worth noting that, when I opened the unit up a few minutes after the load testing, the 3300uF was too hot to touch.
c_hegge wrote:I recapped the two on the 5vsb and the 3300uF 16V cap...
c_hegge (in the review) wrote:The secondary heat sink, on the other hand, is tiny.
Compared to its 80plus bronze certified cousin (the IP-S400EQ3-2), this unit has a slightly reduced 3.3V and 5V capacity (90W vs 120W), and a slightly increased 12V capacity (390W vs 300W)
Wester547 wrote:It didn't burn your fingers, though? Since too hot to touch could either mean above 60*C or above 70*C (discolorating and the point where it burns your fingers). And that secondary heatsink could definitely be leaps and bounds better.
LongRunner wrote:Only those???
