The primary capacitors are rated at 680µF and look to be from Nippon Chemi-Con (KMG series to be exact). However, we are sure that these parts are fake. They have short, thick snap-in pins, while real KMG caps have long leads and the KMG series datasheet doesn’t list a 250V 680µF part.
Unfortunately, though, the critical capacitor is made by GoldLink, which is not one of the high quality manufacturers.
The fan is made by Superred. It’s a 1Ball/1 Sleeve bearing part, which are arguably the worst kinds of bearings available – they are noisier than traditional sleeve bearing fans, but are not inherently more reliable.
Fireworks display was entertaining
KZJs have black sleeves, but they might as well be fake in way of their quality despite the fact that they've been out of production since 2007 or 2008...LongRunner wrote:Just for the record, there was a snap-in KMG (as well as SMG) series in the distant past, although I don't have the specifications for either. But even then, the font as well as the colour (real 105°C Chemi-cons have brown sleeves, except for LXY/LXZ/LZA which are dark blue and older KZEs which were green) give the game away.
Not only is there visible damage to the washers and transistors, but it appears that they god hot enough to start de-soldering themselves!
…with the 80m fan version…
