Extras like gold-plating…
The 5VSB rail is a two-transistor circuit, which is a very dated design these days.
Behemot wrote:As for the plating, I am quite sure nickel and similar metals are used for plating on iron or brass. Tin has no way the physical and chemical endurance needed.
I think if the output capacitors fail that it can still have the same effect. I believe you need actual protection on the output to preclude that (like what Hipro use in some of their very old units, a crowbar protection circuit, same with Bestec), not just on the input.c_hegge wrote:btw, I don't think that single transistor, IC driven 5VSB circuits are prone to the same "12VSB" problem that you can get on two-transistor circuits. when the caps go bad on those, I'm pretty sure they just stop working. That said, though, I still think that using Su'Scon on the output deserves 2 points off.
Users browsing this forum: No registered users and 44 guests
