Huntkey shows off outrageous pc chassis at ComputeX 2011
Discuss general technology and news here.
Postby duckula » June 3rd, 2011, 6:30 pm
Huntkey shows off outrageous pc chassis along with its top-notch power supply (huntkey X7 1200W).
It's not just the random shapes these shards are made of, but also the physical texture, that add originality to this design. The case looks like it's supported by a central SECC-made frame with shards all over it. The front panel looks like a set of random drive bay and fan bay covers, one even has a worn-out StarCraft logo. The surface carries splashes of rusty colors, worn out silvery surface, and patches of red, denoting that the "pre-apocalyptic" X7 may have been a metal-overall case with red paint. Inside, the case has components located in places where some of the first ATX tower cases had them: PSU on the top, a top drive-cage with four 5.25" bays, and one 120 mm rear exhaust apart from two 120 mm front intakes. There are top-exhausts, too, but they're made to appear like they've been drilled out later. The case is sure to make heads turn at LAN parties. Make sure you complement it: go dressed in a worn-out anti-radiation overcoat.
http://www.techpowerup.com/146823/Huntk ... ncept.html
RE: Huntkey shows off outrageous pc chassis at ComputeX 2011
Postby shovenose » June 3rd, 2011, 6:38 pm
:lol: that's really cool case! If only it weren't a Huntkey.
Postby c_hegge » June 3rd, 2011, 6:48 pm
It looks ancient.
Postby shovenose » June 3rd, 2011, 6:54 pm
Lol. But I think that's why it's cool!
Return to General Tech Discussion/News
