IBM Polymod project
IBM Polymod project
Postby c_hegge » May 31st, 2011, 3:48 pm
This motherboard came from an SFF IBM Thinkcentre. Unfortunately, the CPU has a prescott core, and so it gets hot and there is a vented cap next to the chipset heatsink. I'm gonna replace some of them with solid polymer caps.
RE: IBM Polymod project
Postby duckula » May 31st, 2011, 3:57 pm
:rapidfire: prescott.
Postby shovenose » May 31st, 2011, 5:16 pm
I've seen that. Ruby and Nichi HM/N?
Postby c_hegge » May 31st, 2011, 5:18 pm
Yup. The vented cap is a nichicon HM. The date code tells me it was made in 2004, so it was before they fixed the problem some time during '05
They HMs will get Ruby MBZ as their replacment, the row next to the CPU socket will get Chemi-con PSA and the rest will get Sanyo OSCON SEP and SEPC
Postby shovenose » May 31st, 2011, 5:24 pm
But those ones aren't bloated?
Postby c_hegge » May 31st, 2011, 5:25 pm
They're not bloated, but I'm replacing them anyway. They've been baked all their life and I think that polys will handle it better
Postby shovenose » May 31st, 2011, 5:29 pm
I guess you don't go by "if it aint broke dont fix it"
Postby c_hegge » May 31st, 2011, 5:30 pm
Sometimes, but not usually. I'm a big fan of preventative maintenance
Postby shovenose » May 31st, 2011, 5:33 pm
lol ok
Users browsing this forum: No registered users and 29 guests
