How much diskspace do you ACTUALLY use?
Discuss and share about web hosting and domain name providers.
Postby Morsec0de » June 3rd, 2011, 8:26 am
A lot of people choose to buy 'unlimited' hosting when they don't need much space at all. Most people use 100MB space, maximum, as not many people have websites that need a lot of space.
So, how much space do you use?
Morsec0de
RE: How much diskspace do you ACTUALLY use?
Postby shovenose » June 3rd, 2011, 9:19 am
Hardware Inaights uses about 1.5gb i think but i dont remembed i will have to check later.
Postby Morsec0de » June 4th, 2011, 12:34 am
shovenose wrote:Hardware Inaights uses about 1.5gb i think but i dont remembed i will have to check later.
MyBB is 1.80 MB (default). With some plugins, it will be more. You've got the frontend blog, and that's all I can find.
I highly doubt this site is uses 1.5 GB of disk space.
Morsec0de
Postby shovenose » June 4th, 2011, 5:38 am
Lol it's actually 600MB
Postby Morsec0de » June 4th, 2011, 11:43 pm
shovenose wrote:Lol it's actually 600MB
Hmm, I guess the blog takes up a lot of space then, as the forum is pretty leight weight.
Morsec0de
Postby shovenose » June 5th, 2011, 8:15 am
Yep. WordPress is very resource-heavy.
Postby Morsec0de » June 11th, 2011, 5:31 am
shovenose wrote:Yep. WordPress is very resource-heavy.
When I used it, it wasn't. However I did optimize it a hell of a lot.
Morsec0de
Postby shovenose » June 11th, 2011, 2:59 pm
Well I never bothered to optimize it :P I installed a plugin that makes it faster but I barely noticed the difference. I think the problem is that webhostigpad.com has a slow web connectoin.
Postby Morsec0de » June 12th, 2011, 11:26 pm
shovenose wrote:Well I never bothered to optimize it :P I installed a plugin that makes it faster but I barely noticed the difference. I think the problem is that webhostigpad.com has a slow web connectoin.
You must have a pretty bad line if you say it's slow. It's fine for me. You should just optimize it if you find it slow.
Morsec0de
Postby shovenose » June 13th, 2011, 6:28 am
Thos is weird. Many people say it's fine and that it is fast enough. Others, includong me and my friend with a fiber internet connection to his house thst is AFAIK more than 200mbps, thijk its really slow...
Return to Web Hosting
Users browsing this forum: No registered users and 31 guests
