HWIDCFA (HWI Detailed Computer Failure Analysis)...
Postby shovenose » March 26th, 2011, 7:45 am
Every time you witness a computer failure/thing needing repair, or your own computer breaks, please vote for which category the failure is in...
The HWIDFCA will provide valuable insights (pun intended) into the reliability of computers and which component(s) is (are) the most likely to fail.
Thanks for participating. The poll will go on for 90 days. Then, I will create an in-depth analysis of the results!
RE: HWIDCFA (HWI Detailed Computer Failure Analysis)...
Postby c_hegge » April 2nd, 2011, 1:28 am
Malware is the most common I problem I see at work, but if you're looking for the most commonly failed kind of hardware, probably motherboards
