Video issues - computer or LCD?
Postby shovenose » June 21st, 2011, 1:48 pm
Well, I have my nice Dell 22" LCD hooked up to my Compaq PC. Now I'm having issues.
I need help telling if my issues are on the screen or in the computer.
I took a screenshot. If you see the bad pixels then that means it's the computer not the screen, right?
The issue first appeared about half an our ago while Windwos Movie Maker was saving a movie (a CPU intensive task)...
Entire lines across the screen came and went, now there are only individual pixels...
I don't know what to do? :-( is my screen or my computer broken?
I'm trying to run prime95 to see if it makes it worse but so far I can't tell. I'm gonna try FurMark next.
RE: Video issues - computer or LCD?
Postby shovenose » June 21st, 2011, 3:09 pm
Well, I tried a different screen and it still happened. It was an nVidia graphics card so failures aren't too unusual. I replaced with a Geforce 6800 Ultra (the broken one is a 7900GT), and now everything is fine again! :D I am ahppy!
Postby duckula » June 21st, 2011, 3:41 pm
I see two light blue pixels on the picture, so I think it's not your monitor's problem. Well, I think you already know that.
This happened to my friend's xfx 7300GT too a couple of years ago. I replaced his video card with mine and all these unpleasant pixels were gone.
Postby shovenose » June 21st, 2011, 4:36 pm
Yep :-) I'm happy it's fixed!
Postby c_hegge » June 22nd, 2011, 2:25 am
:rapidfire: nvidia
Postby shovenose » June 22nd, 2011, 7:14 am
now I'm using a Seasonic 300W PSU (i might put the antec or a different one back in since the Seasoinc makes an annoying noise), and an ATI Radeon HD 4350 1GB (the 6800 Ultra was too hot) and i added a blue fan near the hard drive lol
Postby duckula » June 22nd, 2011, 6:15 pm
shovenose wrote:i might put the antec or a different one back in since the Seasoinc makes an annoying noise
Could it be coil whining?
Postby shovenose » June 22nd, 2011, 7:02 pm
I think so.
Postby duckula » June 22nd, 2011, 7:23 pm
That's annoy.
Postby shovenose » June 22nd, 2011, 10:16 pm
Yeah. It's not that annoying, and the PSU has less extra cables than the Antec. so I might leave it.
Coil whine is harmless, right?
Users browsing this forum: No registered users and 45 guests
