SMPS
Discuss general technology and news here.
SMPS
Postby bharath » July 18th, 2011, 5:18 am
I had problems with my smps and it is sending low voltage tp MB and also the fan wont revolves.what could be the problem in this smps.I wanna want to buy a new one instead of repairing this but i had an extra fan too to replace and the only problem is low voltage
bharath
RE: SMPS
Postby Th3_uN1Qu3 » July 18th, 2011, 9:08 am
Low voltage + failed fan -> probability of failed capacitors = 110%
Th3_uN1Qu3
RE: SMPS
Postby c_hegge » July 18th, 2011, 4:24 pm
+1
Open the cover and check the caps.
RE: SMPS
Postby bharath » July 19th, 2011, 5:32 am
thanks
for your answers i will give it to nearby repairer shop or i may check it by myself as i did electronics.
Also when it was working it restarts so many times and some times monitor wont start at all but the cpu fan revolves and even dvd rom light blinks as very low voltage.
Anyway will report it back to you guys
bharath
Return to General Tech Discussion/News
