Right, basically My system has an 18 Pin PSU which is faulty and irreplaceable , they are discontinued
so I decided to buy a replacement small form factor PSU from Ebay , which fits snugly , however it has a more common 20 pin mobo connector
So I cut off the old 18 pin connector and spliced it to the new PSU . I noticed the original PSU has most of the standard colour wires found on most PSU's . I did double up on the extra red and black wires .
I noticed the old PSu and connector had a 3.3 v brown sensing wire , which the new PSU didnt have , so I left it unconnected
Also the New PSU has a blue wire , which the motherboard connector doesn't have
Everything else I connected up , the hard drive , 4 pin CPU and 4 Pin Monitor ( though had to split one yellow wire for the monitor as I run out )
I will post up some pictures , generally I have just matched up most of the colours and this has worked for someone else who has posted here http://www.bearware.co.uk/2011/02/03/sony-vgc-m1-psu-fix/
Seems like these 18 Pin PSU are common on Vaio All-in one Series desktops
