PC Design FAIL
PC Design FAIL
Postby c_hegge » September 18th, 2011, 12:08 am
See if you can find what's wrong with this. Actually, on second thoughts, maybe it would be easier to find what's right with it.
The PC is a mITX with a Core 2 Quad CPU, no case fans, an nVidia chipset, a cheap sleve-bearing graphics card fan (which was ceased up), and TK and G-Luxon capacitors all over the motherboard (and yes, the TKs were vented when I got my hands on it).
The picture was taken after I downgraded the CPU to a core 2 duo, added a chipset fan (a sunon maglev ball-bearing), removed the graphics card, and replaced the TK caps with Nichicon HM and the G-Luxons with Rubycon ZL. I had to mod the PSU a bit to get power to the fan. The only spare connector was the extra 4 pins on the 24 pin ATX connector (the mobo only has a 20-pin connector). I cut the connector off and soldered a 3-pin fan connector in it's place (using the 5v rail to power the fan, since it spins at like 4 or 5000 RPM at 12v and makes too much noise).
No prizes for guessing what brand it is :D
PC FAIL.JPG (681.35 KiB) Viewed 24628 times
Re: PC Design FAIL
Postby duckula » September 18th, 2011, 1:50 am
I think it's an ACER. The Aspire marking on the chassis is a giveaway.
Re: PC Design FAIL
Postby c_hegge » September 18th, 2011, 3:29 am
It is indeed an acer.
I hate how this new forum software doesn't attach images as thumbnails, or resize them, but you have to scroll through them.
and I REALLY hate the design of this PC
:rapidfire: acer
Re: PC Design FAIL
Postby duckula » September 18th, 2011, 4:04 am
:D That's a strange configuration. I won't put a quad core CPU and a discrete video card and a 3.5" HDD and a 5.25" ODD in one little computer case if I build a little PC. Most likely I will go with something like atom or APU(E350). :mrgreen:
And I agree with your comment on the attachment.
Re: PC Design FAIL
Postby c_hegge » September 18th, 2011, 5:02 am
Well, it came with windows vistrash, so an atom or similar would have been underpowered. I think that the best option would have been to use an atom and bundle it with XP. You simply can't cool a quad core CPU in that little case, period.
Re: PC Design FAIL
Postby shovenose » September 18th, 2011, 11:05 am
Im working on the forum software nitpicksn..when I'm done moving andhave internet on Wednesday
Re: PC Design FAIL
Postby shovenose » September 18th, 2011, 11:07 am
Then again I've got a PC design fail of my own. An overclocked p4ht 3.2 oc to 3.4, with no case fans a fanless antecedent phantom 350w Psu ;)
Re: PC Design FAIL
Postby c_hegge » September 18th, 2011, 3:12 pm
*gasp* Shame on you for building that :D
I ALWAYS add case fans to my PCs. I have hundreds (literally) of spare ones which I've scavenged from PSUs and soldered connectors onto.
Re: PC Design FAIL
Postby shovenose » September 19th, 2011, 6:13 am
Lol...the autocorrect on my phone turned antec into antecedent...
Yeah it smells funny after a while but it only takes small fans not 80mm!
and it is too loud otherwise. I did change the psu to an antecedent ea380 with a fan and I backed down the overclock...maybe I will add a fan controller ;)
Re: PC Design FAIL
Postby c_hegge » September 19th, 2011, 4:50 pm
I wouldn't even bother overclocking a Prescott, because when they warm up, they throttle back, so you may actually be reducing its performance.
Users browsing this forum: No registered users and 42 guests
