Count to 2013 by 2013
Re: Count to 2013 by 2013
Postby c_hegge » October 30th, 2011, 1:30 pm
It's been like 715 hours since I've seen you, duckula. good to see you again
Postby shovenose » October 30th, 2011, 1:49 pm
Hi duckula/ Glad to have you back!
Hopefully after 716 posts Duckula will notice that he's supposed to write something with each number...
Postby c_hegge » October 30th, 2011, 2:02 pm
haha.
Boeing 717
Postby shovenose » October 30th, 2011, 4:55 pm
Have you crashed that 718 times?
Postby c_hegge » October 30th, 2011, 5:14 pm
I've never crashed a 717 once actually, but maybe I will after another 719 flights
Postby shovenose » October 30th, 2011, 7:46 pm
Your computer will have broken by the time you have done another 720 flights probably ;)
Postby c_hegge » October 30th, 2011, 10:07 pm
Nah. With the Gigabyte motherboard, Delta PSU and WD Hard disk, it will probably last another 721 years.
Postby shovenose » October 31st, 2011, 4:29 am
The fans are going to fail 722 hours earlier though.
Postby c_hegge » October 31st, 2011, 2:56 pm
ah, yes, and then I'll replace them with modded ball bearing fans that have 723 blue LEDs on them
Postby shovenose » October 31st, 2011, 4:21 pm
But all those LEDs will use 724W of power and you will need to upgrade your PSU...
